Subject: To download dotnetuke 4.0.1
ambatisreedhar
14 Aug 2008 2:23 AM
         I need to download the dotnetnuke 4.0.1 to upgrade the dotnetnuke website to version 4.6.2.
The dotnetnuke version 4.0.1 is not available in www.dotnetnuke.com website.please tell me the URLs where i can download this.
Sreedhar
14 Aug 2008 9:17 PM
If you follow the link to the "legacy downloads" at the bottom of the downloads page, you'll find it.
ambatisreedhar
18 Aug 2008 6:28 AM
i have downloaded it from www.sourceforge.net
Sreedhar
Forums > DotNetNuke® > DotNetNuke® Questions > To download dotnetuke 4.0.1
