Subject: Moving UserAcounts to the Main menu ...
Mahkameh
13 Aug 2008 5:33 AM
I want to give permission to one of my security roles to use user acounts and add new users, but I dont want him to see all the control panel and have administrator access level. Would you please help me to move UserAcounts from admin menu to my main menu.
13 Aug 2008 8:01 AM
hello,
Unfortunately this is not possible, even if you move the user accounts page outside of the admin menu, when a user without Administration level trys to create a new user it will inform them that they are not authorised.
Hopefully, this feature will be available when DotNetNuke version 5 is released,
Forums > DotNetNuke® > DotNetNuke® Questions > Moving UserAcounts to the Main menu ...
