Subject: Show renewal message for expired roles
pseaapps
04 Aug 2008 6:56 PM
Is there a way to use DNN to display a message for those members who need to renew?  If I make content only available to a certain role, expired roles will not see the content or anything telling them that their membership has expired.
04 Aug 2008 9:45 PM
One way to do this would be to put those members who are about to expire into a special security role, and then use a module that displays only for that role. You could also send emails to people in that group, or you could send personalized emails.
The trick will be to do the role assignment automatically. You could probably set up a scheduled task to do this -- add a particular role if they are within N days of expiration, and then run the scheduled task every night. The greatest drawback to this approach is that you'll have to have some programming skills to do this, or access to someone with the necessary skills.
On a quick look, it appears that Ventrian's Subscription Tools module may do some of this.
Forums > DotNetNuke® > DotNetNuke® Questions > Show renewal message for expired roles
