Subject: How to apply separator between menu?
kaustav_kar
28 Jul 2008 7:06 AM
In dnn:NAV how shall I add  separator?
<dnn:NAV runat="server" id="dnnNAV" ProviderName="DNNMenuNavigationProvider" CSSControl="main_dnnmenu_bar" CSSContainerRoot="main_dnnmenu_container" CSSNode="main_dnnmenu_item" CSSNodeRoot="main_dnnmenu_rootitem" CSSIcon="main_dnnmenu_icon" CSSContainerSub="main_dnnmenu_submenu" CSSBreak="main_dnnmenu_break" CSSNodeHover="main_dnnmenu_itemhover" NodeLeftHTMLBreadCrumbRoot=""*"" />
28 Jul 2008 7:02 PM
I've been looking for the correct attribute, but documentation on the new NAV menu seems to be well hidden. I hope that Lee or someone else can help.
05 Aug 2008 5:09 AM
check out this post where I listed the various properties available with the Nav Menu, including separator
Forums > DotNetNuke® > DotNetNuke® Questions > How to apply separator between menu?
