Subject: To change the background of the contentpane in DNN website
ambatisreedhar
26 Jul 2008 7:56 AM
I have to set the background of the content pane with a image in Dotnetnuke  Website.which are the files to be modified to the change the background of the content pane?
Sreedhar Ambati
26 Jul 2008 9:41 AM
It would be your skin.css file and your skin file.
ambatisreedhar
26 Jul 2008 10:12 AM
         I have set a image file has a background in site settings, changes are reflected in all the panes except the content pane.what is the class which is to be modified to change the background of the content pane in dnn website?
Sreedhar
26 Jul 2008 10:25 AM
You'll need to look at your skin file to see the classes and IDs.  You can also use the Web Developer's Toolbar to track these down.
Take a look at Troubleshooting DotNetNuke Skins for some ideas.
kaustav_kar
29 Jul 2008 4:02 AM
<TD class="contentpane" id="ContentPane" runat="server" valign="top" align="center">TD>
make a class named contentpane that has been applied in the contentpane TD. in the class write
.contentpane
width: 200px;
height: 20px;
background-image: url(image1.jpg);
Forums > DotNetNuke® > DotNetNuke® Questions > To change the background of the contentpane in DNN website
