Subject: How to create a Search Page?
jeffd
22 Jul 2008 1:11 PM
I want to create a separate search page and have the search button link here instead of the search module.
Any suggestions or is there a video on this already that I missed?
23 Jul 2008 3:12 AM
If you go to admin menu / pages
Here you will see a page named Search Results, here you can edit the search page to suit your needs.
Hope this helps, thanks,
Forums > DotNetNuke® > DotNetNuke® Questions > How to create a Search Page?
RE: Pop up window by jncraig
Pop up window by yerann
