Subject: Migrating from dnn 3.x to 4.x
ambatisreedhar
14 Jul 2008 7:08 AM
Hi, I am migrating my website from versio dnn3.x to dnn4.x,to migrate from dnn3.x to dnn 4.x,I am migrating my site from dnn3.2.0 to dnn 3.3.7 and then trying to migrate from dnn 3.37 to dnn 4.8.4,But there were errors so that i was unable to login to my ebsite.please give me a solution whether i can migrate the dnn3.2.0 to dnn 4.8.4 directly? if so can you
please help me how to migrate dnn from 3.2.0 to dnn 4.8.4.
- SreedharAmbati
14 Jul 2008 8:36 AM
I would try it this way:
  • 03.00.02 (I don't see a 3.2.0 in the legacy downloads list) to 04.00.00
  • 04.06.02
  • 04.08.04.
15 Jul 2008 6:31 AM
  You may also want to have a look at this tutorial which outlines some of the techniques I used on DNN creative:
How to Upgrade DotNetNuke v3.x to v4.4.1
Forums > DotNetNuke® > DotNetNuke® Questions > Migrating from dnn 3.x to 4.x
