Subject: How to create menu
kaustav_kar
14 Jul 2008 6:21 AM
How can I create the menu like the given website
http://wsiwebexcel.ie/Home.aspx
14 Jul 2008 8:42 AM
Looking at page source: Menu generated by TransArt, www.dnn360.net
You can also do this with the DNN Nav menu, Snapsis Menu, or others.
Forums > DotNetNuke® > DotNetNuke® Questions > How to create menu
