Subject: Whats New Module
fmrock
11 Jul 2008 3:07 PM
Hey Everyone,  just found this forum.
I have the a DNN portal setup and is hosted on godaddy.
I have a whats new modual setup and i made some changes to the settings of my Calendar.
I turned on reoccouring events, and now everyday it puts those on the whats new section.
I can remember what settings i updated to get the calendar events on the whats new module.
Any suggestions?
12 Jul 2008 8:56 AM
Are you using Efficon's module? I've never looked at it, so really can't comment on how to configure it.
fmrock
12 Jul 2008 2:54 PM
Not sure, it was just availble with the godaddy hosting solution.
I have installed DNN from scratch at work, and know it does not come with it.  But not sure what versiion Godaddy has.
Is there anyway for me to tell?
12 Jul 2008 3:02 PM
If you look in Host, Module Definitions page you might be able to see something. You'll at least see a version number. If that's not enough, click the edit pencil, you'll see some more stuff. If that's not enough, you can look inside of the module's folder in the DesktopModules folder.
