Subject: How to display menu vertical/Horizanta using snapsis menu
rao_babu24
11 Jul 2008 8:50 AM
and also how to apply css to the snapsis menu
thanks
 advance
11 Jul 2008 8:51 AM
Take a look at the samples and the instruction manual that come with the menu.
Forums > DotNetNuke® > DotNetNuke® Questions > How to display menu vertical/Horizanta using snapsis menu
