Subject: How to get Gestbook module
rao_babu24
11 Jul 2008 8:46 AM
thanks advance
11 Jul 2008 8:50 AM
There is not a guestbook module that's part of the DotNetNuke release. Look for one a snowcovered.com.
Forums > DotNetNuke® > DotNetNuke® Questions > How to get Gestbook module
