Subject: How to Feedback modules and Guestbook module
rao_babu24
11 Jul 2008 8:45 AM
 pls reply any one know.
 I am new for this Dotnetnuke
thnaks
advance
11 Jul 2008 8:54 AM
I answered the Guestbook question on another thread you started. Feedback is available from the Downloads section at DotNetNuke.com.
Forums > DotNetNuke® > DotNetNuke® Questions > How to Feedback modules and Guestbook module
