Subject: reference
deepa
11 Jul 2008 6:32 AM
hi,
I am using flash file in my website.whether we have to add reference to dispaly the flash image in the website.
help me.
thanks,
deepa
11 Jul 2008 8:21 AM
This might help:  How to display Flash Games in DotNetNuke.
deepa
14 Jul 2008 7:57 AM
thank u for ur kind reply.
But i am going to use flash image over in the banner.For that i want to add reference.kindly let me know how to add the reference in .netnuke application.
thanks,
deepa
14 Jul 2008 8:37 AM
If you want to use this in the banner pane, put a Text/HTML module in that pane, and paste the code to embed the flash file as the "header" of the module. This is available in the advanced section of the module settings.
If you want to add a banner ad, use the script form for the ad.
