Subject: How to change the file name is NukeMeUp.DocumentControl
kaustav_kar
10 Jul 2008 7:59 AM
I'm using the NukeMeUp.DocumentControl and I've uploaded several files there. I've to change the name of some files. I've tried but the file names are not changed. Plz help
thanks,
Kaustav
12 Jul 2008 8:58 AM
I've never used this module. Can you get help from whoever created it?
Forums > DotNetNuke® > DotNetNuke® Questions > How to change the file name is NukeMeUp.DocumentControl
