Subject: File Upload Problem
UmaRam
07 Jul 2008 7:57 AM
I have to get user's photo when they update their profile. I am using HTML file control as well as fileupload control to get the photo path.
But after selecting the path, if I click upload button, the content in the fileupload control is not found.
Also I have analysed the default modules present in the application. In Admin\files\Webupload control page, the html File control is used to get tje image. In that page, the value of the fileupload control is maintained properly.
Can you please let me know how can i upload the user's image usinf the html's file control or fileupload control ?
Uma
12 Jul 2008 9:03 AM
Without doing the kind of analysis that you've already done, it's hard to give an answer.
You might want to ask in the DotNetNuke forums where the fileupload control is discussed.
12 Jul 2008 9:03 AM
Is that the standard ASP.NET file upload control that you are using?
Forums > DotNetNuke® > DotNetNuke® Questions > File Upload Problem
