Subject: How to change the settings of the browser to change the textbox color
kaustav_kar
07 Jul 2008 6:00 AM
In my site there are 4 textboxes. I've changed the background color to Gold, but the firstname & last remains yellow and the others remain gold. Where I've to do changes.
10 Jul 2008 1:30 PM
depends on the ids and current styling you have and the form you are using, do you have a URL to view?
Forums > DotNetNuke® > DotNetNuke® Questions > How to change the settings of the browser to change the textbox color
