Subject: Registration
billkidwell
06 Jul 2008 11:09 AM
I am trying to offer a different registration process (fileds captured and landing page for going onto a paying subscription) to a subset of people who will be invited to register and subscribe to my site www.immaag.com.
Do I set up a separate registration page? Or is there something on the existing page I change to get them to a different subscription page? Also, I do not want this group (a different industry) to go through the same registration questions.
I viewed the tutorials on registration and fields and they didn't help.
07 Jul 2008 8:24 AM
You might want to take a look at Dynamic Login and Dynamic Registration from DataSprings.com.
