Subject: "Esperantus.Localize" threw an exception.
mschott397
20 Jul 2006 1:30 PM
We have a shopping cart in DNN 3.1.1 by someone that no longer supports us.   When they left us they told us that the Shopping cart was ready to go with the exception of some graphics that were too large etc.   The design and structure was suppose to be in place and ready to go live.   However, every time I try and access anything that has to do with the shopping cart, I get this error message:  The type initializer for "Esperantus.Localize" threw an exception.    Can anyone help me out with this.    Mike
youngboy
21 Jul 2006 5:52 PM
Found this by Googling:
change the process from Medium Pooled to Low (IIS)
Don't know if it helps or not.
Good luck.
Forums > DotNetNuke® > DotNetNuke® Questions > "Esperantus.Localize" threw an exception.
