Subject:  deploy developed wedsite
rao_babu24
04 Jul 2008 5:51 AM
how to  deploy developed wedsite
thanks advane
04 Jul 2008 6:12 AM
You may find these tutorials useful,
How to transfer a localhost DotNetNuke installation to a live website
speregud
25 Nov 2008 12:47 AM
Hello
how to deploy a local web site on new instance with already working many portals?
Thank you
25 Nov 2008 9:10 AM
The links in the message just before yours in this thread are good places to look.
Forums > DotNetNuke® > DotNetNuke® Questions > deploy developed wedsite
