Subject: Calendar Strobe?
RussCCCom
03 Jul 2008 9:02 AM
Hello, everyone, new to the forum and program.
I'm having a dilemma with an event calendar on a site I'm working on.
http://watauga.cccom.com/Default.aspx?TabId=60
In Firefox, it's fine. But, IE has to always be the complicated browser and add problems to everything. In IE, it has this kind of "strobe" effect. It's like one event can't stand still and so it goes where it pleases. Can someone look at this, and maybe get me in the right direction to what is going on?
Thanks a lot!
04 Jul 2008 9:29 AM
Welcome to th forum, when I hover over a link in IE7, IE6 they display just the same as FF2 - have you fixed the problem?
Does anyone else see the problem?
Hello,DNN Nav is available with the default install of DotNetNuke and already installed. - Just look...
RE: Congratulations to Lee and the DNN community! by leesykes
Hello,Glad to hear it is useful. I didn't go for the DVD, but went for the net effect magazine, rece...
RE: Register and Login Links by jncraig
The general scheme is that CSS styles are attached to skins.  I believe that it's possible to switc...
RE: User Import from Excel by jncraig
I have used John Mitchell's script (http://blogs.snapsis.com/PermaLink,guid,c9d3082b-d7b1-4dfb-8c9c-...
User Import from Excel by sstoos
I'm working on a website that the client has several 100 members that they want to add as users.  Is...
RE: Menu bar and CSS by wsiwpg
Ok, i have now added some sub pages to the site. Can you please go look at it now.Thanks.
RE: DNN Creative News Feed not Working? by mgordon
In my humble opinion, the latest News Feed Module (version 4.00) is a complete piece of crap.  It ha...
RE: Register and Login Links by Faith
Joe: Two short questions. 1) It is possible to set a css style sheet for a determined user? ...
Hello, Below is a few paragraphs outlining some background, but my question is: Can I take a p...
RE: DNN Creative News Feed not Working? by ollep
  One last bit before bedtime.   With the below section in the “.xsl” I managed to get it down to...
RE: DotNetNuke UK User Group Meeting by leesykes
This meeting is now cancelled due to insufficient numbers, we will try again in the new year
  Hi Again.   Seems like the “News Feed Style Sheet” option is changed to “XSL Transformation? A...
Hi Again.   Now I’m on to the News Feed Module and RSS Feed.   Is the News Feeds 04.00.00 quite ...
RE: Query regarding menu by jncraig
Doing that forces a reload and recompile of your site.
RE: Query regarding menu by ImageSmith
I have had this problem before. A quick fix: retouch the web.config file by opening in notepad, make...
RE: Trying Flash again - in Firefox. by jncraig
Here is how we have done it ... Note that I put in a bunch of spaces to break the tags, so you'll ...
RE: Changing the House Menu?? by ollep
Thanks lee. The configuration for the separate sub-menu-item list, do you show that in a tutorial...
Trying Flash again - in Firefox. by ollep
I still looking for ways of running Flash Movies in Firefox??? The code provided in the DNN Creat...
Thanks Joe! Just tested and it works fine.   Only thing was that I could only save in the portal ...
Congratulations to Lee and the DNN community! by ollep
On Lee’s recommendation I ordered the “Stompernet DVD” and the first issue of “Net Effect” – and che...
