Subject: Calendar Strobe?
RussCCCom
03 Jul 2008 9:02 AM
Hello, everyone, new to the forum and program.
I'm having a dilemma with an event calendar on a site I'm working on.
http://watauga.cccom.com/Default.aspx?TabId=60
In Firefox, it's fine. But, IE has to always be the complicated browser and add problems to everything. In IE, it has this kind of "strobe" effect. It's like one event can't stand still and so it goes where it pleases. Can someone look at this, and maybe get me in the right direction to what is going on?
Thanks a lot!
04 Jul 2008 9:29 AM
Welcome to th forum, when I hover over a link in IE7, IE6 they display just the same as FF2 - have you fixed the problem?
Does anyone else see the problem?
