Subject: Is posible creating multiple website (portal) in a single DNN installation?
aravinthkula
03 Jul 2008 8:09 AM
Is possible for creating multiple website (portal) in a single DNN installation. If so, how to do that and how to access those created Website(Portal). I need the steps.
Please do the needful, its very urgent for me
Regards
Aravinth K
03 Jul 2008 8:22 AM
Yes, that's one of the main features of DotNetNuke.
To create a new site, go to the Portals entry on the Hosts menu dropdown.
When you create a new website, you will see the URL for the site.  You can also use the PortalAlias feature to give it a different URL.  You will also need to configure DNS to point the external domain name at the DotNetNuke installation.  DotNetNuke will handle the redirection of the requests to the correct website.
Also, I'd recommend that you view the tutorials here that are relevant.  Some of them are:
aravinthkula
04 Jul 2008 12:47 AM
Thanks for your reply.
Actually we followed a approach like created different portal like portal1 and portal2 Its portalalias name is locahost/portal1 and localhost/portal2.
create 2 virtual directory in IIS with the name Portal1 and Portal2.Both the virtual directory point to the same DNN installation.
In browser i can use like this, http://localhost/portal1/default.aspx and
http://localhost/portal2/default.aspx. we can acccess this portal by using this link and able to login.
Could you please tell me the above mentioned approach is correct or not?
Please do the needfula asap.
As you mentioned in your reply,
I cant get what you have mentioned.can u please clear about that?
regards,
Aravinth K
04 Jul 2008 6:05 AM
You can do that approach, if it is a localhost installation, you may find it quicker to create child portals and then you do not need to configure IIS for every single portal, the URLs would then be:
http://localhost/dnn_install_name/child_portal_name
For the DNS, this is referring to setting up multiple portals on a live website and the configuration of this is dependant on your hosting provider and your hosting package.
if you set up child portals you will not have to setup any further configuration
if you are using unique domain names with parent portals you'll need to point all of the domain names to the same DotNetNuke installation files
Forums > DotNetNuke® > DotNetNuke® Questions > Is posible creating multiple website (portal) in a single DNN installation?
have a look here
Database error by derpir
This might help you: DotNetNuke.Entities.Users.OnlineUserInfo It's always better to use the busin...
RE: Query regarding clearing cache by jncraig
Query regarding clearing cache by kaustav_kar
Hi,In my site which is in Dot Net Nuke to clear cache I want a button. Is there any code with the he...
MY FIRST DNN SITE by mattshortland
hello I am just working on my first dnn site and wondered what you all think? http://letcombebass...
New CSS site feedback please! by dp6ai
I've just designed my first CSS site. I'm not sure how well it works because the client was so keen ...
I have added a new Profile Property to Users (Company name) Does anyone know how to change the la...
