Is possible for creating multiple website (portal) in a single DNN installation. If so, how to do that and how to access those created Website(Portal). I need the steps.Please do the needful, its very urgent for meRegardsAravinth K
Thanks for your reply.
Actually we followed a approach like created different portal like portal1 and portal2 Its portalalias name is locahost/portal1 and localhost/portal2.
create 2 virtual directory in IIS with the name Portal1 and Portal2.Both the virtual directory point to the same DNN installation.In browser i can use like this, http://localhost/portal1/default.aspx andhttp://localhost/portal2/default.aspx. we can acccess this portal by using this link and able to login.Could you please tell me the above mentioned approach is correct or not?Please do the needfula asap.As you mentioned in your reply,You will also need to configure DNS to point the external domain name at the DotNetNuke installation. DotNetNuke will handle the redirection of the requests to the correct website.I cant get what you have mentioned.can u please clear about that?regards,Aravinth K
Subscribe to the website - Sign up now for just £39/$78 per year!
Subscribe to the website Sign up now for just £39/$78 per year!
New Releases
