Subject: How to make the dropdown list filed mandatory
kaustav_kar
01 Jul 2008 8:25 AM
I'm working in dataspring dynamic module. I've created several dropdown list field. Besides this there are text field also. I've made the text filed mandatory, and the same option in question validation has been applied for this field. But the dropdown fields are not becoming mandatory filed.
Forums > DotNetNuke® > DotNetNuke® Questions > How to make the dropdown list filed mandatory
RE: Database error by derpir
Hello thanks for the tip Lee but I can't find were to change the Authentication mode on my SQL Serv...
have a look here
This might help you: DotNetNuke.Entities.Users.OnlineUserInfo It's always better to use the busin...
RE: Query regarding clearing cache by jncraig
Query regarding clearing cache by kaustav_kar
Hi,In my site which is in Dot Net Nuke to clear cache I want a button. Is there any code with the he...
