Subject: How to add fields in the register form
kaustav_kar
01 Jul 2008 2:50 AM
How to add new fileds in the register form that appears when we click on the register control of dnn.
01 Jul 2008 6:06 AM
You may want to view these:
kaustav_kar
02 Jul 2008 6:42 AM
We have gone through the processes that are provided in the reply. But it's not showing the additional fields. We are using dnn 4.5.5 and also 4.8.2. Whenever we go to add new field there is no option for Update button. It's only showing the Next button. And then at last a Save button comes. After clickin on the save button the fields are not being added. Please help.
02 Jul 2008 7:41 PM
You need to work through those screens an then click the update button. Make sure that the fields are marked as Visible, and that you also require a valid profile for registration.
An alternative would be DataSprings Dynamic Registration and Dynamic Login modules.
Forums > DotNetNuke® > DotNetNuke® Questions > How to add fields in the register form
