Subject: Transeferring live site to local host
llamadeanor
30 Jun 2008 6:11 AM
Hi to everyone.
I'm a beginner in dotnetnuke.
I have search in the forum for if it is answered in somewhere else but I did found nothing. Sorry if it is answered.
I'm trying to transfer my live website to my local host, so I follow the video turorials Transferring_live_site_to_localhost. But I'm having a problem. I will be grateful if someone could help.
I'm blocked on the step of restoring the .bak datafile.
I follow the tutorial instructions, selecting the .bak directory, but when I press "ok" in the order to restore the database, an error message appears the system can't find the directory C:\Archivos de programa\Microsoft SQL Server\MSSQL.1\MSSQL\DATA\DNN.msf
But actually ...I have my .bak file in C:\Archivos de programa\Microsoft SQL Server\MSSQL.1\MSSQL\Backup\DNN_Monday.BAK as the tutorial says.
Thanks in advance!
llamadeanor
30 Jun 2008 8:30 AM
Don't mind!
I could solve it by myself.
The problem was that the database restore was traying to restore as the root C:\Program Files\Microsoft SQL Server\MSSQL.1\MSSQL\DATA\DNN.mdf when actually the root was C/Archivos de Programa\Microsoft SQL Server\MSSQL.1\MSSQL\DATA\DNN.mdf.
It was because of the default root language.
Hope this can be useful fo someone else
Regards!
01 Jul 2008 5:55 AM
Glad you got it sorted, thanks for posting your solution,
Forums > DotNetNuke® > DotNetNuke® Questions > Transeferring live site to local host
Glad you sorted it, thanks,
