Subject: Installation on Vista or Windows server 2008
bobUre
26 Jun 2008 9:44 PM
I recently attempted to do clean installs to a Vista  Business Machine and a Windows 2008 server box.  I followed the ISS - 7 configuration instructions in the "Installing to Vista" tutorials. The DB is on SQL Server 2005. The The DNN Version was 4.8.4. The install dialog runs to to the point where the "Go to Site link appears. The Database is populated. However, IE hangs without rendering any pages.
The same behavior happens if DNN 4.7.0 is used.
DNN 4.8.4 installs fine on XP
Does anyone know the solution?
26 Jun 2008 9:48 PM
Windows Server 2008 could be the problem. I'd recommend that you check over on the DotNetNuke site to see if this is supported in the current release.
Forums > DotNetNuke® > DotNetNuke® Questions > Installation on Vista or Windows server 2008
RE: Expanded sections (Advance settings) collapses automatically! by maxdagenais
Thanks,Yes, I did restart IIS and event the server to make sure but no luck.Again, the issue seems t...
URL Question by bmatthews
Is there a way to make the URLs a little friendly.What I am looking to do is make a page and access ...
Hi Lee, Thanks for getting back to me. Our DNN and portal DBs are 2000 and I did a full backup t...
RE: Upgrade DNN 2.1.2 to use SQL 2k5 by leesykes
Have you tried backing up the SQL 2000 database and then restoring it into the SQL 2005 server?You s...
Oh, and we can't upgrade to a new version of DNN because our custom modules are only for 2.1.2 and i...
Hello,We are currently using SQL Server 2000 with DNN 2.1.2.  We would like to upgrade to SQL Server...
RE: Issue customizing DNN by jncraig
DNN skins for "older" versions should work just fine with 4.9.0.
RE: Issue customizing DNN by leesykes
You could download an earlier version of DNN to get hold of the skin files for DNN Blue, the entropy...
RE: Issue customizing DNN by jberry
The tutorials were very valuable and I am back on track.  In the latest version, the only skin and c...
have you created the username + password access that you specified in the connection string for the ...
. I have access to all folder permissions, and it was working. I just don't enough about the install...
Hello,There is not an easy way to change them to hover over submenu items. When using the house menu...
Thank you both for the replies.  I will get back to the basics here.
RE: How to send mail using the smtp settings by jncraig
I have set up DNN to use a gmail account as the SMTP server. If I remember, you must use xxxx@gmail...
RE: add modules on login and register forms by jncraig
If you login as Host or Admin, you will have a control panel from which you can add modules to pages...
How to send mail using the smtp settings by sherlock005
Hi,I am not able to send the mail.I checked the smtp settings in host settingsi set the smtp server ...
add modules on login and register forms by blanketstream
hi , gaysi have made a site . In skin i was put tag , it is displaying on my pages. when i click on ...
RE: One Year Now, and gladly signing up for a second! by DavidWSnow
A year ago I started this thread and had some very positive comments about DNN Creative Magazine.  M...
RE: Expanded sections (Advance settings) collapses automatically! by jncraig
When generalized behavior like this starts, stopping and restarting IIS sometimes works.
Hi,I apologise for all the happy faces which seemed to have been caused by cutting & Pasting of the ...
