Subject: Available Modules
freedom22
26 Jun 2008 8:16 AM
I am trying to add a module to my dotnetnuke page, but when I click "add module' it seems that a smaller number of available modules appear than do in Lee's tutorial. Is there a setting for "short menu list" as opposed to "full menu list"? Or, what am I missing. I am trying to add a Documents module.
Thanks in advance,
Mark
mark@freedom22.org
26 Jun 2008 8:24 AM
You need to "install" modules into DotNetNuke before you can add them to a page.
When you first install DotNetNuke, it doesn't automatically install every available module. If you go to Hosts, Module Defnitions and scroll to the bottom of the page, you'll find a list of modules that you can install by checking them off and clicking an install link.
If there are other modules not on that list, you can download from the DotNetNuke site, and then install them on that same page, but using the dropdown menu. You can also install third party and other modules this way.
freedom22
26 Jun 2008 8:40 AM
Thanks jncraig,
That did the trick.
Mark
ok great, glad to help,
