Subject: CSS issue
scorpionsera
25 Jun 2008 5:17 AM
Can anyone help me
Actual css font color is "Balck". working in all browser but not Firefox.
Result in Firefox showing some hidden style before login. It works fine after login.
<font style="color: rgb(255, 255, 255);">Loginfont>
element.style {
color:#FFFFFF;
25 Jun 2008 5:45 AM
I'm not sure what you are trying to do, could you try explaining again please?
ok great, glad to help,
