Subject: Notification System
UmaRam
19 Jun 2008 6:07 AM
I have to create a new module to send email once the new user registers in the child portal.
Is there any notfication module available in DNN?
If not how to do this?
Uma
19 Jun 2008 8:34 PM
Notification to new users is a part of the DotNetNuke registration process. You can modify the text of the message using the language editor.
Forums > DotNetNuke® > DotNetNuke® Questions > Notification System
