Subject: Copying a module
davidrushton
17 Jun 2008 12:53 PM
I'm probably missing something here but I can't seem to find a way to copy a module.  We have a standard form that we want to use as a template for forms throughout the site and then modify each form accordingly based on the page it is on.
I thought the answer was to "add existing module" in the control panel, but this seems to reference the original module, and when one is updated they all are.  Is there a way to make a copy which acts seperately from the original?
Cheers
Dave
17 Jun 2008 1:29 PM
You could add the form module as a new module to a page
Go to the original - export content from module settings menu
Go to new module and import content from the original
davidrushton
18 Jun 2008 4:46 AM
Hi Lee
I'm using Complete Feedback Designer and there does not seem to be functionality to Import/Export content.
Is there another way of doing this?
18 Jun 2008 7:31 AM
Go to the admin control panel, select Copy Page (when viewing the module you wish to copy)
Enter the details for the new page
Scroll to bottom - under 'Copy Page' selet the module to copy
You have options for New / Copy / Reference - select the type you require
Click update
Checkout: Page Management – New Functions DotNetNuke v4.5.x
davidrushton
18 Jun 2008 8:04 AM
I have just tried this but the "copy" option is greyed out. Is it a case that the module just doesn't support this?
18 Jun 2008 8:15 AM
It looks like that is the case then - it may be worth contacting the original module developer and asking them to implement this functionality.
