Subject: Search Error
markdurham
17 Jun 2008 9:07 AM
Hello, Whenever anyone tries to search for something on my site is just defaults to the homepage rather than showing a list of search results.
Does anyone have any ideas why this maybe ?
thanks
Mark
17 Jun 2008 9:47 AM
First thing I would check is - do you have a search results page? - Go to Admin menu / Tabs (Pages)
Is a Search Results page listed here?
markdurham
19 Jun 2008 3:38 AM
There wann't a search results page, I have now added this but is has not changed anything.
I added the search results page and added the search results module ?
Any other ideas ?
Mark
19 Jun 2008 4:39 AM
not sure, if I was testing this I would setup a second fresh DotNetNuke installation and then compare it to your current installation.
The next check would be to see if the search is scheduled in Host menu / scheduler
