Subject: Multiple zip files in one DNN package
Marcusw
05 Jun 2008 5:20 PM
I have developed 5 modules that are all dependent on each other. Each one has its own .dnn, sqldataprovider and zip files.
Is it possible to package multiple zip files into one main zip file and if so how is this done? Any help/thoughts much aprreciated.
Forums > DotNetNuke® > DotNetNuke® Questions > Multiple zip files in one DNN package
