| RE: Regular restores to local machine by joannew |
| Hello Lee, Thanks for the info, I tried restarting the application but it had no effect. Is there... |
| RE: menu in dotnetnuke by leesykes |
| The page URL option does not have the option to open links in a new window, they will always open in... |
| RE: Only registered users can access some parts of the module by leesykes |
| thanks for posting info, |
| RE: Blog Module on 4.8.4 by leesykes |
| I just tested the comments in DNN 4.8.4 and blog 3.4.0 and they work ok.Go to the blog list module s... |
| RE: File Manager Upload (intermittent error) by leesykes |
| It sounds as though you do not have permission to upload js files using the file manager. To check t... |
| RE: News Feeds (RSS) module 4.0 ? by leesykes |
| It works in exactly the same way. Go to 'edit newsfeed' - enter the RSS URL for the newsfeed source ... |
| RE: style search CSS or XML by leesykes |
| The CSS code for that skin is:#dnn_dnnSEARCH_txtSearch { height:16px; position:absolute; top:4px;... |
| RE: News Feed from DNN Blog by leesykes |
| Hello,I tested with blog module 3.04.00 and News Feeds 3.01.01It should work, can you display other ... |
| RE: Query Regarding search fuctionality by leesykes |
| You can contact venexus direct for any questions regarding their modules, |
| RE: Query Regarding search fuctionality by kaustav_kar |
| Thanks for your help. Could you please tell me how to configure it? |
| RE: Only registered users can access some parts of the module by nukedoubt |
| Solution Obtained !!!!!!!Follow the steps :To Checked In login mode as registered users or not -
Do... |
| RE: Blog Module on 4.8.4 by bryan_homey |
| 03.04.00 Thanks Bryan |
| RE: Repository template: YouTube by bryan_homey |
| Thanks! |
| RE: File Manager Upload (intermittent error) by dnnmq |
| banner_rotator.js is only 3KB. This behavior was reported after we upgraded from 4.3.4 to 4.8.3.Bef... |
| RE: templates and modules by mmcinulty |
| Hi Bocheck back to issue 24 for info about page templates.about your other issue with modules login ... |
| templates and modules by cyborama |
| Hello Lee and Joe,My first question deals with templates. I noticed in dotnetnuke apparently you ca... |
| News Feeds (RSS) module 4.0 ? by wolmar |
| I had some trouble with the old NewsFeeds module (the one coverd in tutorial) so i figured i'd insta... |
| style search CSS or XML by mmcinulty |
| CSS an XMLi was looking back at issue 29 about search styling. there was a skin i seen www.dnnskin.n... |
| RE: Query Regarding search fuctionality by jncraig |
| I believe that the Venexus search tools can be configured to do that. |
| RE: Create Bookmarks/Anchor Points/Page TOC by jncraig |
| I'm not aware of a module that does that. And, yes, you have to put the links in manually. I've us... |
