Subject: SolPartMenu and organization
cyborama
20 May 2008 4:06 PM
I am using the SolPartMenu as my navigation system and have recently had to add a page or two to this menu.  Consequently enough I have had issues of it not popping into place in terms of alphebatical order rather it popped at the end of the pages in a given category.  Is their anyway in Dotnetnuke to within the admin>pages or elsewhere to specify you would like your pages to be organized in alphebetical order.
I am not sure when this problem started weather it was due to one of my upgrades or not but nevertheless if you have any insightt hat would be great.
Bo
Nuke Master I
Nuke Master I
20 May 2008 8:47 PM
I don't believe that there is a place to specify that pages are in alphabetical order. But, you can go to the Admin, Tabs (or pages) menu and move the order of pages around manually.
Forums > DotNetNuke® > DotNetNuke® Questions > SolPartMenu and organization
RE: GoDaddy by greenflash
RE: GoDaddy by aggiedan97
