Subject: FCKEditor + Behavior
mgordon
20 May 2008 10:03 AM
Hi All,
I'm having a frustrating time with the FCKEditor.  When I go to edit the text, it defaults to the Basic Text Box instead of the Rich Text Editor.
When I change it to Rich Text Editor and Save my changes, then, later I go back into it to make more changes, it has defaulted again to the Basic Text Editor.
Any ideas?
I'm using 4.5.1
Thank you all!
20 May 2008 8:52 PM
Ummm ... no. But I hope somebody else has some ideas.
Forums > DotNetNuke® > DotNetNuke® Questions > FCKEditor + Behavior
ok great, glad to help,
