Subject: login module
Bobbyjosephg
20 May 2008 3:48 AM
   The login module becomes blank when the user successfully logs in.Is there any configuration setting so that it displays the username and a logout link.Or should I build a custome version of the login module?
Regards
Bobby
Nuke Master I
Nuke Master I
20 May 2008 9:17 AM
What I do is use the standard dnnUser and dnnLogin skin objects wrapped in some conditional coding so that they are only visible when people are logged in.
            < %  If DotNetNuke.Security.PortalSecurity.IsInRole("Registered Users")  Then % >
                < td align="right" height="100%" style="width: 100%" >
                    < div id="LoginUserContainer" >
                        < dnn:User cssclass="BannerLinks" runat="server" id="dnnUser" url="" / >
                         < dnn:Login runat="server" cssclass="BannerLinks" id="dnnLogin" / >
                    < /div >
                < /td >
             < % End If % >
Note that I've used spaces so the < and > arent interpreted as tags in the post.
Member log in by HUGHD37IUOE
Video Problem by icdlbake
