Subject: New DNN site -old database
saintX
14 May 2008 2:20 AM
Hello, I have made a new installation of my DNN site in a subdomain and have connected it to the data base of the old site, which is still online untill the new site gets ready.
Every time I hit a link of the new site, it jumps to the old site. Can I make some changes so that the new site works correctly?
14 May 2008 8:46 AM
You need to adjust your site's Portal Alias in the Portalalias table.  These tutorials cover that item:
Forums > DotNetNuke® > DotNetNuke® Questions > New DNN site -old database
