Subject: html text module
efelcee
12 May 2008 1:43 PM
my html/txt module does not look like the one on the video help supplied.  My txt does not allow me to edit text and therefore does not have the editor/word processor available.  So I cannot follow the video help as mine does not look like the one they have on the video??  Please help
12 May 2008 1:46 PM
It would appear that there is something wrong with your installation's Text/HTML module. Can you go to the Module Definitions page under Host Settings and tell us which version is installed? Also, which version of DotNetNuke are you using?
RE: Pop up window by jncraig
Pop up window by yerann
