Subject: How To Increase FCK Editor Time Out ?
saqib389
12 May 2008 8:50 AM
Hi There
Can any one please tell me that how can we increase the FCK module timeout..
We are getting problem when we update the module after a little while then our session closed, so we have to write again...
Looking forward to hear from you
MANY tHAnks
Saqib
12 May 2008 9:00 AM
Here are some things to check:
In web.config, set
<form>s name=".DOTNETNUKE" protection="All" timeout="10080" slidingExpiration="true" cookieless="UseCookies"
You can use another number for the timeout. It is in seconds.
In Host Settings, under Performance Settings, set Page State Persistence to Page.
Set Authenticate Cacheability to public.
If you have access to IIS settings then you should set Content Expiration for your site which does the same thing for static files like images, js, & css.
Forums > DotNetNuke® > DotNetNuke® Questions > How To Increase FCK Editor Time Out ?
RE: Pop up window by jncraig
Pop up window by yerann
