Subject: Skinning the store checkout
icaustonltd@hotmail.co.uk
11 May 2008 8:24 PM
Dear all,
I have installed the default store module but I have noticed that the checkout will only show the admin skin.
I want to have a different skin for the site and the admin area.
Has anyone solved this issue?
Thanks in advance
17 May 2008 8:03 PM
Have you viewed Lee's review of store modules?  If not, check out Issue 30.  I don't know if the answer to your question is there, but it certainly might me.
19 May 2008 8:14 AM
Your tutorials didn't cover the bug but it might be worth touching on at some point because its a biggy, in my opinion. You cannot style/skin the checkout pages with anything other than the chosen admin skin. In the end I created a new module to hold all the same functionality and linked to the page without using the functionality to replace a module dynamically on the same page
Yes this is probably something that needs adding to the module, I would suggest you put a request in with the store module project team and see if they can add it into a future release.
Forums > DotNetNuke® > DotNetNuke® Questions > Skinning the store checkout
Glad you sorted it, thanks,
