Subject: Not Really A DNN Question
mgordon
09 May 2008 11:16 AM
But I am hoping you've addressed this in one of your tutorials.
I need to have a subdomain/child portal(?) to my www.pwcparks.org website.  I need it to be:  report.pwcparks.org, or something like that.  Have you done a tutorial that shows how to create  or mess with Host Headers?  If you have, which tutorial would I use?  I do have the #17 issue, but it shows how you've already created Host Headers?
Thanks....btw, Joe...Mitchel Sellers is proving to be a godsend in help.  Thank you for referring me to him.  He is worth every penny,  just like DNN Creative is worth every penny.
Lee, I hope everything is going well with you.  Cheers!
Nuke Master I
Nuke Master I
09 May 2008 11:24 AM
Mark,
All that you need to do is create the second site, and it can be either a child site or a parent site.
You then have your DNS set up so that report.pwcparks.org will point to the same IP address as your other site. Finally, add a portal alias for report.pwcparks.org in your new site.
That should do it ...
I'm glad my other recommendation is working out, too!
mgordon
09 May 2008 11:53 AM
Hi Joe,
That's where I'm being thrown for a loop...setting up the DNS.  I'm with the county and do  not have access to their DNS server.  Am I going to need to have them do this?  If so, what exactly should I be telling them to do?  I only have access to my IIS Server.
Mark
Nuke Master I
Nuke Master I
09 May 2008 11:59 AM
Yes. If they manage your DNS, they are the ones with whom you will have to deal. Tell them that you want the new domain to point to the same IP address as the existing domain. On your end, all that you have to do is add the portal alias entry for your new site. You can do that now, leaving the existing alias. Then, you'll know that they've done their part when the new domain works.
mgordon
09 May 2008 12:08 PM
OK, but where do the Host Headers in IIS come in?
I've contacted the county and they are going to add the pointers to the urls I want.  So that's going smooth.
mgordon
09 May 2008 12:19 PM
Nuke Master I
Nuke Master I
09 May 2008 12:33 PM
No, I think that will break things. The requests should be forwarded to the DotNetNuke installation, and DotNetNuke then uses the Portal Alias entries to send the responses. This is ALL handled within the single DotNetNuke installation.
mgordon
09 May 2008 12:35 PM
Forums > DotNetNuke® > DotNetNuke® Questions > Not Really A DNN Question
RE: Assign a css id to a module. by corourke
Thanks for the suggestion jncraig. I've made the suggestion: http://support.dotnetnuke.com/issue/Vie...
RE: Host menu gone? by vijaymoharle
Hi, Host is  menu is  available for  Superuser. When you  install DNN it will ask for  New Admin a...
dotnetnuke compiler error by wdarnellg
I am trying to transfer my dotnetnuke files from localhost to my live account. I have followed the s...
RE: Assign a css id to a module. by jncraig
I agree. Why don't you make that suggestion at dotnetnuke.com.
RE: Document management Modules by jncraig
I'm not aware of a module with all of these features. If you find one, please let us know.
RE: how do i get my home link to work.... by jncraig
Can you ask this again. I don't understand the issue.
RE: Default Events Module XHTML by emedia
I can't seem to locate the Visual Studio Solution file for the Events Module, I know most modules no...
how do i get my home link to work.... by cipher2079
how do i get my home link to work again, I am trying to get back into web building and I complete fo...
Hey guys,I'm new to DNN and have been trying to make a specific install of DNN XHTML compliant.  Gen...
How can I implement .net forms authentication in DNN? by pvirk
Hello,I am in the process of migrating an existing asp.net website over to Dot Net Nuke.  This websi...
Fixing Ugly URL's by digitaldoom
I've noticed that the QueryStrings in DNN (with Friendly URLs turned off) show Tabid=XXX.Is there an...
RE: Host menu gone? by digitaldoom
I had this problem also... My whole Host account is gone. When I login with Admin and I view a...
That's what I've been doing so far however that adds extra divs which isn't the most semantic way to...
Editing Blog Module to say News instead of Blog by omorgan
Hello,I'm trying to find where I can edit the blog module from saying Blog to make it say News. My b...
RE: Document management Modules by jfitzgerald
Ideally the following Check in\ out facility – Giving audit trail of who has ‘checked out’ the do...
What functionality would such a module have?
RE: control panel keeping rolling up by jncraig
Well ... I haven't seen this problem in IE, so your job might not be over ...
Hi Guys,I'm trying to find out if dnn has an advanced document management module?Can anyone help??Ma...
RE: control panel keeping rolling up by rizwan7705
thanks for trying to help me out but problem was with windows internet explorer 7.when i tryed firfo...
RE: Main Menu Bar by jncraig
If you learn a little bit about skinning, you can do this easily by removing those controls from the...
