Subject: Store Module Paging
davidrushton
02 May 2008 6:28 AM
I'm looking for a bit of help with the standard store module...
I have installed the store module for a client and everything was working fine.  My client then asked me to create a number of pages on the website (one for each store category) and only show one category on each page.
So I created a number of pages, placed a catalog module on each and set it not to show the default category and show the relevant category instead.  This works until the catalog module starts paging.  When you click to go to the next page within the category the user gets redirected to the default store page defined in the store admin settings.
Has anyone got any ideas on how I can get it to stay on the same page and just show the next set of products within the category?
Any help would be greatly appreciated
Cheers
David
10 May 2008 3:02 AM
I have just setup a test store how you have described and I can replicate the problem. This appears as though it is a bug in the store module rather than a configuration problem. I would contact the store module project team and see if they have a solution to the error.
davidrushton
11 May 2008 10:42 AM
Hi Lee,
Thanks for your reply. I have just modified the database directly setting the store page ID attribute in the store administration table to null. This seems to do the trick atleast until the bug is fixed.
Cheers
Forums > DotNetNuke® > DotNetNuke® Questions > Store Module Paging
Hello,DNN Nav is available with the default install of DotNetNuke and already installed. - Just look...
RE: Congratulations to Lee and the DNN community! by leesykes
Hello,Glad to hear it is useful. I didn't go for the DVD, but went for the net effect magazine, rece...
RE: Register and Login Links by jncraig
The general scheme is that CSS styles are attached to skins.  I believe that it's possible to switc...
RE: User Import from Excel by jncraig
I have used John Mitchell's script (http://blogs.snapsis.com/PermaLink,guid,c9d3082b-d7b1-4dfb-8c9c-...
User Import from Excel by sstoos
I'm working on a website that the client has several 100 members that they want to add as users.  Is...
RE: Menu bar and CSS by wsiwpg
Ok, i have now added some sub pages to the site. Can you please go look at it now.Thanks.
RE: DNN Creative News Feed not Working? by mgordon
In my humble opinion, the latest News Feed Module (version 4.00) is a complete piece of crap.  It ha...
RE: Register and Login Links by Faith
Joe: Two short questions. 1) It is possible to set a css style sheet for a determined user? ...
Hello, Below is a few paragraphs outlining some background, but my question is: Can I take a p...
RE: DNN Creative News Feed not Working? by ollep
  One last bit before bedtime.   With the below section in the “.xsl” I managed to get it down to...
RE: DotNetNuke UK User Group Meeting by leesykes
This meeting is now cancelled due to insufficient numbers, we will try again in the new year
  Hi Again.   Seems like the “News Feed Style Sheet” option is changed to “XSL Transformation? A...
Hi Again.   Now I’m on to the News Feed Module and RSS Feed.   Is the News Feeds 04.00.00 quite ...
RE: Query regarding menu by jncraig
Doing that forces a reload and recompile of your site.
RE: Query regarding menu by ImageSmith
I have had this problem before. A quick fix: retouch the web.config file by opening in notepad, make...
RE: Trying Flash again - in Firefox. by jncraig
Here is how we have done it ... Note that I put in a bunch of spaces to break the tags, so you'll ...
RE: Changing the House Menu?? by ollep
Thanks lee. The configuration for the separate sub-menu-item list, do you show that in a tutorial...
Trying Flash again - in Firefox. by ollep
I still looking for ways of running Flash Movies in Firefox??? The code provided in the DNN Creat...
Thanks Joe! Just tested and it works fine.   Only thing was that I could only save in the portal ...
Congratulations to Lee and the DNN community! by ollep
On Lee’s recommendation I ordered the “Stompernet DVD” and the first issue of “Net Effect” – and che...
