Subject: Store Module Paging
davidrushton
02 May 2008 6:28 AM
I'm looking for a bit of help with the standard store module...
I have installed the store module for a client and everything was working fine.  My client then asked me to create a number of pages on the website (one for each store category) and only show one category on each page.
So I created a number of pages, placed a catalog module on each and set it not to show the default category and show the relevant category instead.  This works until the catalog module starts paging.  When you click to go to the next page within the category the user gets redirected to the default store page defined in the store admin settings.
Has anyone got any ideas on how I can get it to stay on the same page and just show the next set of products within the category?
Any help would be greatly appreciated
Cheers
David
10 May 2008 3:02 AM
I have just setup a test store how you have described and I can replicate the problem. This appears as though it is a bug in the store module rather than a configuration problem. I would contact the store module project team and see if they have a solution to the error.
davidrushton
11 May 2008 10:42 AM
Hi Lee,
Thanks for your reply. I have just modified the database directly setting the store page ID attribute in the store administration table to null. This seems to do the trick atleast until the bug is fixed.
Cheers
Forums > DotNetNuke® > DotNetNuke® Questions > Store Module Paging
RE: GoDaddy by greenflash
RE: GoDaddy by aggiedan97
