Subject: AJAX Error
rogerg1967
29 Apr 2008 5:27 AM
Hi, I am trying to get doc store 4 working on a website but get the following error
AJAX Extensions for ASP.Net were found in the local bin directly, but not installed in the GAC (Global Assembly Cache). Real-time rotations are enabled but may not behave correctly.
Can anyone help. Thanks
RE: PowerDNN by jazzylily
RE: PowerDNN by DavidWSnow
RE: PowerDNN by mgordon
Great!
RE: PowerDNN by MobileNow
