Subject: Employee directory - how would you do it?
16 Apr 2008 8:14 PM
Here's a loosely defined project, and I'm wondering out loud how might be the best way to do it.
Suppose that someone wanted to create an employee directory.  For each employee we would want to store and image, name, email address, skills, education, brief biography, and perhaps a few more items.
Then, I'd like to have httpp://mysite.com/..../joesmith point to the page where Joe Smith's data is displayed in a standardized format.
If Joe Smith logs in, I'd like for Joe to be able to edit and save his information.
Which, if any, DotNetNuke module would you use to do this?
eureka
17 Apr 2008 1:18 AM
Hi Joe
Xmod will do this - biography directory here:
http://www.peermomentum.com/Resources/SpeakersBios/tabid/84/Default.aspx
Lynn
asaph
21 Aug 2008 12:23 PM
Hey Lynn,
I looked that the linked page above. I purchased Xmod and neither I nor the Xmod people could get it to work on my corporate Intranet (problem with the uploaded image URLs). I need this directory page ... urgently. We are moving toward the release date and the one feature that the GM requested isn't working... the employee directory.
Is it possible to get the a look at the code for the peermomentum.com bios page? That page is exactly what I need.
Please advise. Thanks!
Forums > DotNetNuke® > DotNetNuke® Questions > Employee directory - how would you do it?
