Subject: Telerik RadMenu
ollepet
16 Aug 2006 7:33 PM
Hello!
I'm just wondering if there will be some tutorial videos about Telerik's RadMenu (and other products from them) in the near future? I have downloaded the trial of this product, but it seem to be too many things to control at the same time. Just to tell, I downloaded the radmenu skinobject for the first time this week so I have not spend so much time discovering it. But I will appreciate if there will be some tutorials out there soon so it would be easier to start. I know that Telerik's radmenu is not a free product, but I think it is the most advanced product out there when it comes to dotnetnuke menus.
I have also discovered the housemenu lately and will take a closer look at it as a replacement for the solpartmenu, but my wish for the future is a videoseries of Telerik's RadMenu and other products from that company.
At last I want to tell that I like this site very much. Keep up the good work!
/Sweden
17 Aug 2006 2:51 AM
Hello and welcome to the site!
I haven't used the RadMenu but I will add it to the list of tutorials to look at. I am going to setup an area where subscribers can suggest tutorials and can vote for the tutorials that they need. This will be a couple of months away as deadlines are very tight for getting the issues complete over the next 2 months.
Once I have set that up I will add the RadMenu to the suggested tutorials and let the subscribers vote for it.
The HouseMenu is a useful menu and the tutorials on here should get you started with that menu quickly.
Thanks for the suggestion and I will get the feedback area setup as soon as I get the spare time.
Lee
Rinsuind
23 Jul 2008 2:31 AM
You can find RadMenu Integration Manual here: http://dnn.telerik.com/Support/radMenuskinobject/tabid/51/Default.aspx
On that page you can also find Integration Manuals for RadEditor, RadPanelbar, RadTabstrip, RadTreeView and RadUpload.
