Subject: Google adwords vs goodle adsense
Max Dagenais
13 Oct 2009 10:49 PM
Hi Leigh,
We've watched your video on google adsense but i was wondering what the difference is between google adwords and google adsense.
At the moment we have a high profile celebrity called Tom Williams (in Australia) www.tom-williams.com.au who has a hard time getting found in the search engines as there is another celebrity elsewhere with the same name.
Any ideas on how to help improve his "visability" within google would be GREAT.  I have been trying to work out google adwords but the google team are inundated with requests.
Any help is much appreciated.
many thanks
Lindy Olsen
Trimax Solutions.
15 Oct 2009 4:14 AM
Google Adwords is a Google service that allows you to advertise in the search results and also on other websites that display Adsense.
Google Adsense is a small piece of code that you add to your website pages, this will display Google Adwords advertisements, each time a visitor to your website clicks on an ad, you receive a small payment from Google.
Google Adwords is a good way to begin an ad campaign. They do provide a lot of info for free on how to use it, I think there maybe even videos, so its worth looking around the Google Adwords help.
Forums > Users Lounge > Podcasts > Google adwords vs goodle adsense
RE: Skin Header by mcmanta
I'm not aware of any.
RE: Skin Header by WinXnet
RE: Slow login by jncraig
