Subject: Constant Contact (online email newsletters service) $30 credit
15 Aug 2007 11:25 AM
I use constant contact to send out the newsletters for DNN Creative Magazine.
I really like the service that they provide and the costs are reasonable based on how many subscribers you have in your list.
Here's the deal, you can try Constant Contact with their no-risk, FREE 60-Day Trial.  When you become a Constant Contact customer, you and I will both be eligible for a $30 credit to our Constant Contact accounts! - Simple!
Click here to sign up for a 60 Day Free trial and $30 credit if you sign up
thebottgroup
21 Aug 2007 4:58 PM
Hi Lee Im looking to do this to - but before I do I would like when members sign up in my dnn portal that they would automatically be subscribed to the newsletter group at constant contact - have you created a form to do this? constant contact sent me their API's and documentation, but need someone with more advanced skills then I to make that happen. If you have written this could I buy it from you? Or could you recommend a person?
23 Aug 2007 3:31 PM
No I haven't set this up, I just export the list directly from the members who are subscribed to the newsletter role. - This has been on the 'to do' list for a long time. - www.dnnguru.com is a good place to get dnn developers. Thanks,
timruns
14 Nov 2007 7:07 PM
Any update?  I have a client that wants his DNN users to automatically get Constant Contact signup...
Otherwise, is the export/import pretty smooth?
Tim
15 Nov 2007 1:56 PM
I still haven't looked at the automation. - I do the import / export using SQL server and running queries - it's not ideal for a client to be doing this, but for a web designer it is relatively straightforward.
A module for this should be pretty simple to create for an experienced developer, so it may not cost much if you try outsourcing at www.dnnguru.com
thebottgroup
15 Nov 2007 2:24 PM
We used form master and created a newsletter sign up form. Constant contact gave us the API information and we use the "silent post" feature in formaster to pass the data to constant contact.  this works great EXCEPT this only adds user to the constant contact mail list at constant contact - it does not create a user on my dnn portal. So for us it usable but I would love to figure out how to have a form create a dnn user also---- let me know if you figure it out
here is our form
 http://www.know-the-cause.com/Newsletter/tabid/60/Default.aspx
AndyC
19 Dec 2007 4:40 PM
I'm new at this, but can somebody clarify the major advantages of using one of the services like constant contact? Doesn't DNN include built-in functionality for drafting and sending newsletter type e-mails to your subscriber list based on roles? Do the services merely provide more features? Better interface? Or is it a bandwidth issue related to the size of your subscriber base and/or the size of the messages you are sending?
I guess my point is partly - why would I want to pay for another service to manage newsletter delivery when I can (in theory) do this easily myself via DNN?
19 Dec 2007 4:49 PM
Good question. - I had to look for another way of sending emails once my list grew above 1000. - After 1000 it would struggle to send them all. The other advantage you get is that these online email services work to get a high deliverability rate, so basically you are more likely to get your emails delivered through a service rather than sending through DotNetNuke. They also have options for delivering both text and text/html newsletters and it automatically sends the version that is suitable for the users client.
If you are starting small, there is no reason why not to use the built in DNN newsletter and then once your list has grown you can look at other areas. - This helps to minimise your costs and test if people are interested in receiving your newsletter before paying for a service.
Hope this helps,
AndyC
19 Dec 2007 7:33 PM
That makes perfect sense.  Thanks for the clarification Lee!
ziadc
27 Feb 2008 4:47 AM
yes
DBS
04 Mar 2008 9:02 PM
Lee thanks for the feedback. One other thing to consider is when sending out newsletters is the volume of emails that comes from your server/domain and maybe considered as spam server if not done properly. Of course I have not found clear details to what "properly" is and have fought with these issues for years. I had to stop sending email newsletters from my server because of "AOL" alone block emails to our members and prevented them from receiving their registration information causing us to lose business.
Forums > Special Bonuses > Readers Offers > Constant Contact (online email newsletters service) $30 credit
RE: Expanded sections (Advance settings) collapses automatically! by maxdagenais
Thanks,Yes, I did restart IIS and event the server to make sure but no luck.Again, the issue seems t...
URL Question by bmatthews
Is there a way to make the URLs a little friendly.What I am looking to do is make a page and access ...
Hi Lee, Thanks for getting back to me. Our DNN and portal DBs are 2000 and I did a full backup t...
RE: Upgrade DNN 2.1.2 to use SQL 2k5 by leesykes
Have you tried backing up the SQL 2000 database and then restoring it into the SQL 2005 server?You s...
Oh, and we can't upgrade to a new version of DNN because our custom modules are only for 2.1.2 and i...
Hello,We are currently using SQL Server 2000 with DNN 2.1.2.  We would like to upgrade to SQL Server...
RE: Issue customizing DNN by jncraig
DNN skins for "older" versions should work just fine with 4.9.0.
RE: Issue customizing DNN by leesykes
You could download an earlier version of DNN to get hold of the skin files for DNN Blue, the entropy...
RE: Issue customizing DNN by jberry
The tutorials were very valuable and I am back on track.  In the latest version, the only skin and c...
have you created the username + password access that you specified in the connection string for the ...
. I have access to all folder permissions, and it was working. I just don't enough about the install...
Hello,There is not an easy way to change them to hover over submenu items. When using the house menu...
Thank you both for the replies.  I will get back to the basics here.
RE: How to send mail using the smtp settings by jncraig
I have set up DNN to use a gmail account as the SMTP server. If I remember, you must use xxxx@gmail...
RE: add modules on login and register forms by jncraig
If you login as Host or Admin, you will have a control panel from which you can add modules to pages...
How to send mail using the smtp settings by sherlock005
Hi,I am not able to send the mail.I checked the smtp settings in host settingsi set the smtp server ...
add modules on login and register forms by blanketstream
hi , gaysi have made a site . In skin i was put tag , it is displaying on my pages. when i click on ...
RE: One Year Now, and gladly signing up for a second! by DavidWSnow
A year ago I started this thread and had some very positive comments about DNN Creative Magazine.  M...
RE: Expanded sections (Advance settings) collapses automatically! by jncraig
When generalized behavior like this starts, stopping and restarting IIS sometimes works.
Hi,I apologise for all the happy faces which seemed to have been caused by cutting & Pasting of the ...
