Subject: Special Offers for the readers of DNN Creative
15 Aug 2007 11:17 AM
Listed here are special offers that we have found for readers of DNN Creative, we hope you will find them useful.
Lee
Forums > Special Bonuses > Readers Offers > Special Offers for the readers of DNN Creative
RE: Database error by derpir
Hello thanks for the tip Lee but I can't find were to change the Authentication mode on my SQL Serv...
have a look here
